TractorLinks.com
Re: Blasting Equipment - Why isn't this Ever Used???
RTR
12-06-2012 11:05:25
For my small use at the house I could see building a wash pad behind my shop (where I would also paint too) that was constructed like a pad at one of those self-serve carwashes. It would all drain to the middle. I could install one of those plastic tanks under the drain and pump it out into a portable plastic tank when necessarry. Think that would work?? It just sounds like it would be the way to go to clean oily, greasy tractors and pull the paint off in one swipe without worrying about silicosis and fumes from the stripper/oven cleaner I use now.
GlenIdaho
12-06-2012 11:50:01
 Re: Blasting Equipment - Why isn't this Ever Used??? in reply to RTR, 12-06-2012 11:05:25
Just to add my 2 cents, it seems to me a guy could easily build a pit to catch the run off. It could be lined with plastic or if you had the money, concrete. You could then allow the water to evaporate and the sediment to dry and then haul away. There would be the issue of some evaporation of any chemicals, but that is probably minimal and occurs under current methods anyway.
I would be concerned about water and what ever media is used getting into places it should not be and then having to do a teardown and possibly a rebuild. Well, hope I didn't spend more than my 2 cents.lol
