| Antique Tractor Paint and Bodywork |
Topic: Re: Primer and prep and paint to use on ford 3000
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Stephen Newell
11-22-2012 20:17:49
63.25.44.16
Winter isn't a good time to paint a tractor. I would wait till closer to spring to do it. You need 60-70 degrees to paint. To do the job right it will need to be stripped down to bare metal and be primed soon after being stripped. I prefer automotive paints and would recommend using epoxy primer and topcoat with a 2k urethane. The paint is expensive but it will last a long time. If you are going to do it now I would start with washing the tractor with a de-greaser and a power washer. If you have access to steam cleaning equipment it would be better. Stubborn grease can be gotten off with oven cleaner. Then with a sandblaster or abrasives I would take strip as much of the existing paint off as you can. Then I would wipe the metal down with a wax and grease remover and let dry. Then on the cast parts go ahead and prime it with the epoxy primer. The tin parts if any body work needs to be done I would hammer out the dents out as much as possible, wipe it off with the wax and grease remover and prime. Any bondo work can be done over the epoxy. After sanding flat there will likely be bare metal spots again from sanding so I would spray another coat of epoxy primer on the bare metal spots. When that dries a surfacing primer should be used because epoxy primer doesn't sand very well. The surfacing primer sands between coats very well. Once everything is leveled out and primed then it should be ready to topcoat. I prefer a 2k urethane. Automotive paints don't normally have instructions on the can so when you purchase the paint be sure to get a specification sheet on any paints you buy. |
[Reply] [No Email] | |
| Rustyj14
12-07-2012 10:10:53
74.109.237.80
| There is one thing not mentioned here, in getting some machine ready for paint, and after sand blasting and sanding! DON'T forget to blow out all of the nooks and crannies as that's where the dirt, dust, and sand blasting stuff lurks! And also, wash (as in clean rags) with a good cleaning product for pre-painting operations, using clean rags, or towels. The clean towels, or other things might leave a bit of lint or dust in the cracks, So another blow off is seemly. If your compressor is old, one of those little ball shaped filters, at the gun end of the air hose will catch most of anything coming from the compressor. But, they won't catch old polishes,oil, wax, etc. Always use a "Tack-rag" right before spraying. available at auto paint stores, and others. Great for small pieces of dust, etc. that may remain before paint work begins! A good practice is to wash the original surface before any work is done, with Prep-sol, or any product for that purpose. then go to the rust removal process and any surface sanding, priming of repairs and final sanding and blow off. Then do the final wash again, tack the readied surfaces again, then apply the finish coats. Always do the things that will produce the best results, before you begin to apply the paint! And---DO NOT use gasoline to wash the surface prior to applying any paint products! If you do--you will end up with a coat of livered paint, which will require a complete removal of all of yer hard work! And--a mess that will make you want to blow yer brains out! Seen that! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
