Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Paint still tacky after 5 days
CNKS
10-31-2012 18:09:10
You should be able to handle it the next day. Some hardeners have an opened period of as little as 2 weeks. I have a product called Bloxygen which expels most of the oxygen in the container, close it quickly and put it in the refrigerator. Still good for a long time. It is either old hardener, or your painter did not use enough of it or did not use it according to instructions.
redgems
10-31-2012 20:46:22
 Re: Paint still tacky after 5 days in reply to CNKS, 10-31-2012 18:09:10
CNKS and all thank you for your help! I think he did not use enough or not used properly. What do I do? do I wait it out ?or do I strip it and start over. Other then being soft it looks great. Tony
glennster
11-01-2012 14:36:02
 Re: Paint still tacky after 5 days in reply to redgems, 10-31-2012 20:46:22
at this point, the deed is done. you can either strip it and re-do, or try and get some heat on it and see if it will cure. if you can get it in a small shop, get a propane torpedoe heater in there and get the temp up to 80 or 90 degrees for at least couple hours. then turn the heat down and let it set for half a day and see what you get. i would stay away from a diesel or kero heater at the solvents are still coming out of the paint, and who knows what will happen with the fuel oil on the finish.
