Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: "20/20" Paint Job and Fender Repair Questions.
Tom in MO
10-18-2012 16:42:33
I visited with my local auto body man today: he says he can improve the looks of the hood, and fabricate a piece for the bottom of the grill, BUT: the fenders aren't worth trying to fix, and I should get replacements.
Here are a few pix. Please take a look, and feel free to share any ideas.
Dick L
10-20-2012 14:31:37
 Re: Re: in reply to Tom in MO, 10-18-2012 16:42:33
Actually the fender is not all that hard to fix. you would need to cut out the cracks and holes and weld in patches. The bent part should hammer out well.
I start to take step by step pictures and then get lazy and forget to take out the camera. The fender is on the tractor now.
showcrop
10-20-2012 17:10:02
 Re: Re: in reply to Dick L, 10-20-2012 14:31:37
Dick L, I do very little body work myself. A friend told me recently that body shops now will frequently glue a panel patch or hole cover instead of welding. I can see many advantages, provided you get all of the rust out first. With glue in there it would leave no place for moisture to get in between pieces and you don't get the expansion that you get from the heat of welding. Is glue in use for body work now?
Dick L
10-21-2012 05:13:34
 Re: Re: in reply to showcrop, 10-20-2012 17:10:02
Might have been a better example.
I like doing it this way to keep the back side as smooth as the front. Also once it is repaired it does not show where the repair was made. I stitch weld and don't get in a hurry. I make a few stitches and work on something else for a bit. When I flub up I cut it out and put in a bigger patch.
Jason S.
10-20-2012 17:49:40
Yes...body shops use panel adhesive quite extensively now. Anywhere from patching panels to glueing complete bedsides in. Personally I do like it for the reason that you mentioned that it forms a complete seal against moisture. If you are worried about strength, I have seen it tested. They glued two pieces of metal together with it and then clamped it between to pulling towers on a frame machine and tried to pull it apart. The metal tore apart but the joint where it was glued didn"t. On a side note..if you get it on a pair of vise grips..the only way to get it to turn loose is with a torch. Don"t ask me how I know...lol
Jason S.
10-18-2012 18:58:28
Those fenders aren"t that bad at all....I don"t see anything that a welder...a couple of hammers and dollies and a half a day"s time couldn"t have looking pretty good. If you were close to me I"d do it for you just to save some original fenders.
Copyright © 1997-2015 Yesterday's Tractor Co.
