Topic: Re: PPG Omni AU or just go with oem Iron Gard paint
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| FordManiac
09-29-2012 18:57:01
72.11.37.183
So i like the omni au mbc but does it stick and protect better? Better uv protection etc. i know it looks better but if it protects less and fades worse then not interested. Thank you for the help. |
| glennster
09-30-2012 02:22:46
99.90.9.201
Re: PPG Omni AU or just go with oem Iron Gard paint in reply to FordManiac, 09-29-2012 18:57:01
| the omni au is a far superior product than the ironguard. however, with the better performance comes the increase in cost for materials and your prep work must be spot on. there is always a trade off. |
| FordManiac
10-02-2012 13:37:31
72.11.37.183
Re: PPG Omni AU or just go with oem Iron Gard paint in reply to glennster, 09-30-2012 02:22:46
| Quoting Removed, click Modern View to see
Glennster,
So i have decided on the Omni AU MBC paint. What steps should i take to clean the tractor and what primer do you recommed? Seems like the etching primers are liked by many.
Thank you |
| glennster
10-02-2012 18:10:40
99.90.9.201
Re: PPG Omni AU or just go with oem Iron Gard paint in reply to FordManiac, 10-02-2012 13:37:31
| for your base primer use the mp 170 in the ppg line. it is a 2k epoxy primer that will go over bare metal with good results. use a ppg 2k surfacer as your fill primer that you will be sanding. for pre prep, pressure wash to degrease, using a wire brush and scrapers to get all the grease, dirt and oil off. some guys use oven cleaner. it will strip off paint, but it takes elbow grease. you need to get down to bare metal. sand blast, soda blast, wire wheel, 3m stripper wheels, ect. before priming clean with a pre-cleano type prep, you can load an old spray gun with it and turn the air pattern way down so it shoots a spot, and wash with that. keep all products containing silicone well away from the tractor. any small amount will cause fisheyes in the paint. here is a link to some mp 170 specs |
| FordManiac
10-04-2012 17:08:07
72.11.37.183
Re: PPG Omni AU or just go with oem Iron Gard paint in reply to glennster, 10-02-2012 18:10:40
| Hello glennster. I had to change from Omni to ppg Delfleet essentials due to color matching problems. Im going to follow your advice above. So i also need the fresh air suit you mentioned in your earlier post. What is the most cost effective option while meeting the safety requirements?
Thank you |
| FordManiac
09-30-2012 05:21:42
72.11.37.183
| Ok thanks glennster. So sounds like it will last, look and protect longer. But will cost more and require better prep work. It may be a little over kill i guess but i really take care of my equipment and want it to look good too. Also the PPG number i tried looks to be spot on which is a plus as well. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
