Urethane vs acrylic
Is urethane by Ppg a better choice over acrylic to paint a show
tractor , rare Oliver el toro? Also, does urethane accept clear
coating vey well? What PSI pressure should be going to the
gun , I assume about 10 psi will be coming out of the gun ,
thanks to anyone with the proper info
PPG has acrylic urethane and acrylic enamel, urethane is better in the same line of paints, such as Omni, not sure they have acrylic enamel in the higher lines. You can clear coat single stage urethane, but there is no need to as clear is mixed with the paint. Guns differ, use the pressure marked on the gun or in the accompaning literature. Do not deviate from that number.
Unless they have quit making it recently Delstar was PPG"s premium acrylic enamel. As far as which one to use urethane will keep its shine longer exposed to the elements and being used but since it"s a show tractor and won"t ever see the elements then it wouldn"t really make a difference.
Delstar is more expensive and likely better than Omni urethane. Same with DuPont Centari acrylic enamel being better than Nason urethane. Centari is still available, not sure of Delstar.
