One of the rear rims on my Ford 4000 has a hole rusted through around the stem. Can a patch be welded in and a new hole be drilled elsewhere? The rest of the rim looks good from the outside.
Thanks Doug
Here are pictures of repair I made to rim on my MF 230
I cut out bad area and put in a 2x3 inch patch across the cutout area at an angle, and heated each end to taper it to match original as best I could trying to keep a flat area for stem to seat on
Certainly a professional looking repair TJ. I don't imagine I would get the same results with my welding ability. I think I will patch the hole and drill elsewhere.
If there is enough metal there to weld a patch there then yes you can. I welded a patch over a valve stem hole just to move the hole to the outside of the rim instead of having the valve stem on the back side of the wheel.
common repair to stitch in a patch or weld a washer over the area..
remember you must dismount the tire first!
At the link is where I repaired a rim from my Dorf 961. I was working the second shift at the time and when I finished it up I didn't have my camera with me. After it was welded in and ground smooth it was not detectable. Cut a patch of good steel from a badly rusted rim from the same that I received from a friend.
Click On picture To Enlarge
