Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Agco PO#2 Paint 101
Ryan Renko
09-01-2012 16:08:03
I purchased a quart of Agcos finest today for $86.90 + tax but I knew the price beforehand and was sitting down. I know I will need more to paint my D17 but wanted to practice on a few pieces before I buy alot more. I was once told the paint can usually has a chart on it about mixing with reducer and hardener but this can does not have one. Questions now- What type of paint is this? I will be using a HVLP gun so how do you know the proper ratio of mixing? I dont want to do this half @ss so I am reading up and hoping you all can guide me along. Thanks in advance everyone. Ryan
MT in Walford
09-06-2012 20:43:31
 Re: Agco PO#2 Paint 101 in reply to Ryan Renko, 09-01-2012 16:08:03
Ryan,
I would agree with the folks who say take it back. It should of come with directions and it sounds too expensive for what you are getting to me.
Josh in Pa
09-03-2012 05:08:44
$86 a quart is very high for AGCO's standard paint, I didn't realize they had a higher grade? $86 per quart would buy urethane automotive paint, and it will probably hold up much better than the AGCO paint. Unless AGCO has a better grade. I'd be interested to know, as I have several olivers and always had paint mixed.
Josh
Rod (NH)
09-01-2012 19:10:21
If the basic usage instructions, such as type of thinner (reducer), mix ratios and recoat info are not specified on the can label, I recommend you return the product for a refund and find a better source for your paint - one that provides proper specific instructions from the manufacturer. Paints are too expensive to proceed based only on what "someone said".
CNKS
09-01-2012 17:45:07
The paints made by DuPont, PPG, Martin Senour, etc have exact mixing instructions, but cost about $170 for the "cheaper" urethane versions. What you have is likely an acrylic modified version of the 1930's alkyd enamel. It could be the newer acrylic enamel but I doubt it. I don't know the mixing instructions but it is probably mixed about 8:1 paint to reducer or 4:1:1 paint:reducer:hardener. If Glennster, B maniac or some other person who knows reads this he can correct me.
Jason S.
09-02-2012 12:12:16
 Re: Agco PO#2 Paint 101 in reply to CNKS, 09-01-2012 17:45:07
If you want to use the Agco paint I"d say 8:1:4 ratio is about right if you are using hardener.
Copyright © 1997-2015 Yesterday's Tractor Co.
