Yesterday's Tractor Co.
Shop Now View Cart
Re: Opinions before I paint
08-21-2012 07:21:48
I use Ospho and have painted over it the enxt day, I have never had a problem with it, been doing it for many years, But if I use lacquer primer it wont stick unless I sand it first, Will epoxy primer be what I should use?
08-21-2012 07:49:09
 Re: Opinions before I paint in reply to BSpauld, 08-21-2012 07:21:48
Lacquer primer is one of the worst as far as adhesion. Epoxy primer is the best and can be used under anything, or over anything for that matter. The lack of adhesion is stated in the instructions for some lacquer primers that say sand AND use etch primer before applications. If you get by with ospho or any phosphoric acid product on cast ok, but I'm not going to try it. Mainly because I remove all the rust I can with a wire wheel on an angle grinder. IMO any rust remaining in the pores of the cast will be sealed in by the epoxy. Some may disagree with the last statement, but epoxy is as good as it gets. The only paint lifting I have seen occurred because I messed up with the application one way or another. I seldom use any phosphoric acid on sheet metal because there is zero rust when I am done. If there is any "microscopic" rust, the epoxy takes care of it. If I ever run into any (the hood on my Super M is badly pitted) I will use Picklex 20 and sand off the residue before it is painted. Picklex does not have to be washed off.
08-21-2012 09:30:54
 Re: Opinions before I paint in reply to CNKS, 08-21-2012 07:49:09
I dont use it on cast either. I will get some epoxy primer, Thanks for the advice.
