Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Painting already primed tractor
OhioWD45
08-21-2012 05:34:42
I have a tractor that I purchased mid-restoration. It is all primed, but this was done many years ago. What should I do to make sure the topcoat will adhere well to the existing primer?
David G
08-29-2012 09:51:01
 Re: Painting already primed tractor in reply to OhioWD45, 08-21-2012 05:34:42
I would give it a light sanding to remove any oxidized primer and paint.
KRS_MED
08-27-2012 08:44:23
Stephen gave great add vise. You don't know what type of prime they used and there are some that calls for the finish to be applied in a certain time frame. Sand it down to metal and start over with quality products. That way you will know what has and hasn't been done.
Stephen Newell
08-21-2012 20:53:44
If it were me I would assume the primer was applied incorrectly and take it down to bare metal and start over. The primer that is on there would be the foundation of the paint job and if it fails no matter how good a paint job you put over it is going to come off. Also it is possible unless it was correctly primed with epoxy primer it could be rusting under the primer without being able to see it.
MT in Walford
08-21-2012 20:37:05
If it was mine, i think I would give it a light sanding and another coat of primer...just me.
LarryM
08-21-2012 13:38:08
Lightly sanding it is the safest thing to do.
Copyright © 1997-2015 Yesterday's Tractor Co.
