TractorLinks.com
How bad can rain (humidity) mess up paint?
Fullers Farmalls
08-08-2012 21:16:36
I have a solid base of primer down. 3 or 4 coats. Started to paint with I.H 2150 and a thunder storm hit. Everything small in in my garage, no humidity control there but its inside and pretty air tight. I started the tractor and had to stop half way through. It's under a canopy and have tarps all around the sides to keep water directly off of it. But it is far from air tight. Help me please. Hahaha
GordoSD
08-09-2012 09:37:16
 Re: How bad can rain (humidity) mess up paint? in reply to Fullers Farmalls, 08-08-2012 21:16:36
Do you have 3-4 coats of that primer on the tin? That doesn't look like epoxy primer to me. If it is not epoxy, you can let that sit as long as you want. Then piprior tp paint wet sand it with a block and paint.
glennster
08-09-2012 05:56:05
if your humidity gets too high when you are painting, it will cause the paint to "blush" . it gets a foggy appearance. if you have about 70- percent or above, i wouldnt shoot it.
Stephen Newell
08-08-2012 21:48:07
A lot would depend on how dry the paint was when it started raining. Really the only thing you can do is wait and see. The parts inside the garage should be fine. If the tractor had any mist blow in around the tarp you may have to sand the paint and put another coat on. That should be the extent of the damage if there is any.
Fullers Farmalls
08-08-2012 21:49:45
 Re: How bad can rain (humidity) mess up paint? in reply to Stephen Newell, 08-08-2012 21:48:07
You sir just made my night. The paint had set for about an hour. And i am pretty sure no water got on it. Thanks for the reply.
Stephen Newell
08-12-2012 05:01:24
 Re: How bad can rain (humidity) mess up paint? in reply to Fullers Farmalls, 08-08-2012 21:49:45
So, what did it look like after it dried?
