Picklex 20 and body filler
Billy C.
Do I use body filler before or after using piclex20? Have a few small dings to fill in--can't get them straight with body tools. Thanks, Billy
Before. I would get the dings within 1/8" of level, actually I try for 1/16", then sand with no more than 80 grit, then apply the body filler. If you feel a need for protection of the sanded areas around the body filler, i.e. you are not painting right away, try to keep the Picklex out of the body filler. I really do not have that problem, as I live in a dry climate, and if the parts are inside, I don't get rust.
