TractorLinks.com
Masking tires Painting wheels
Moondoggie
08-08-2012 07:45:19
I"ve finished painting my 340 Utility, but want to paint the wheels without removing the tires. What is the best way and material to mask the tires when I spray the wheels?
TaylorMutts
09-08-2012 03:00:39
 Re: Masking tires Painting wheels in reply to El Toro, 08-08-2012 07:45:19
I have only done this with automotive wheels, but since you are not even breaking the bead on the tire, I don't think this will be an issue. Deflating the tire allows you to squish it down enough to insert the cards. The larger the diameter of the wheel, the easier it should be to paint in this fashion.
Good luck!
RTR
08-30-2012 09:06:13
 Re: Masking tires Painting wheels in reply to S.billy, 08-08-2012 07:45:19
WOW, I'm gonna have to try that! Does that go for the large rear tires on tractors too!?? What if they got water in the tires?
sflem849
08-09-2012 17:30:02
 Re: Masking tires Painting wheels in reply to Moondoggie, 08-08-2012 07:45:19
Very cool idea Taylor.
TaylorMutts
08-09-2012 17:22:30
 Re: Masking tires Painting wheels in reply to SWMO, 08-08-2012 07:45:19
I've painted a lot of wheels lately. I remove the valve core so the tires fully deflate. I then stick 3x5 cards just under the rim, all the way around the rim. Have not had any issues with overspray, and once done painting just remove the cards, reinstall the valve core and inflate the tire. Much faster and easier than masking.
This post was edited by TaylorMutts at 03:23:06 08/10/12.
Masking tire
08-09-2012 16:59:58
A lot people have put a thin coat of vaseline on the tire so the paint won't stick. There may even be a special type of stuff just for tires. Just be extra careful not to get any on the rim.
davediehl@hotmail.com
08-09-2012 14:23:00
On the rims I paint with tires on, I deflate the tires. It will lower the bead enough to properly paint with less going on the visible part of the tire.
sflem849
08-08-2012 19:43:46
A little thinner on a rag should take care of any overspray if you get it right away.
Moondoggie
08-08-2012 19:03:52
Thanx for the info. I""ll take my time and try to get the masking tight.
B-maniac
08-08-2012 17:12:42
I guess it goes without sayin' if ya ain't dismounting them the ya ain't planning on breaking the bead away from the rim either then. Get some "automotive quallity" green 3M preferably 3/4" tape. It will turn the radius of a tractor tire without parting or pulling up. Press it down extra tight. Make sure and wipe the tire where you are going to mask with laquer thinner to get it clean. After the 3/4" then mask the rest of the tire with newspaper or whatever you have. Nothing tackier than a tire with paint overspray on it. Take your time and get the tape edge right down in as far as you can to the edge of the rim. Shave off any mold nibs that might hold the tape up.
