TractorLinks.com
Sand Blasting questions.
JohnDeereJimOhio
07-30-2012 18:20:38
Just bought a pot belly blaster off ebay for 104 bucks seemed like a good deal and used my neighbors once was very effective. Was wondering what i should buy to shoot through it to clean up my tractors before i paint them?
JRSutton
08-07-2012 17:03:12
 Re: Sand Blasting questions. in reply to JohnDeereJimOhio, 07-30-2012 18:20:38
Tractor supply sells some decent stuff - black diamond. Use the 40/80 stuff to avoid clogging.
Obviously use a good respirator no matter what you use but I'd still be real careful about using regular "sand" - read up on silcosis before you do that, so at least you'll be informed.
Keep in mind too that there's probably worse things in the paint you're removing!
Morris Krodle
08-01-2012 12:31:05
#4 sand is fine enough to pass thru most any small nozzle and does a good job without distorting the metal, if you keep the pressure down to about 110 lbs.
Stephen Newell
07-31-2012 04:26:49
I use all purpose sand. The sand has some aggregate too large to use with the sandblaster so I have a wooden box with screen wire on the bottom to sift it. When I sand blast I put down some polyethylene plastic to catch and reuse as much of the sand as possible. I then use the sifter box to clean the used sand.
