Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Primer dry-time
WI Dave
07-25-2012 09:40:41
I'm using Case/IH primer and 2150 red. If I prime tonight after work, about 9:30, will I be able to paint 12 hours later, tomorrow morning? The label on the can is gone, otherwise I'd just look there.
GordoSD
08-07-2012 19:41:03
 Did you paint yet? in reply to WI Dave, 07-25-2012 09:40:41
I was going to tell you to load up your block sander with some 320 wet or dry paper. Do a little dry sanding. If you get "balls" of primer on your block, instead if "dust" then it isn't dry. You really should wet block sand everything prior to paint for a really pro finish.
WI Dave
07-26-2012 20:05:24
 Re: Primer dry-time in reply to WI Dave, 07-25-2012 09:40:41
I primed it last night. Went to the dealer today before work and checked out a new can: topcoat within 3 hours or after 48 hours.
GordoSD
07-26-2012 20:42:43
 Re: Primer dry-time in reply to WI Dave, 07-26-2012 20:05:24
I'd go with after 48 hours. I used that primer one time about 10 years ago and it was still soft three weeks later.
sflem849
08-05-2012 19:22:08
 Re: Primer dry-time in reply to GordoSD, 07-26-2012 20:42:43
I used it back in 2007 and was really happy with it. I primed on Friday night and painted on Monday because I did it at work.
kevinj54
07-26-2012 04:35:05
 Re: Primer dry-time in reply to William Eccles - Jardine, 07-25-2012 09:40:41
OOPS :oops: just reread his post. :oops:
The dealer will probably read a label for ya!!!!
I do not have any left or I could read it for you.
WI Dave
07-25-2012 19:27:53
 Re: Primer dry-time in reply to J.Wondergem, 07-25-2012 09:40:41
:roll:
showcrop
07-26-2012 04:27:38
 Re: Primer dry-time in reply to WI Dave, 07-25-2012 19:27:53
Happens to all of us, I gave advice for gas yesterday when the poster clearly said diesel
kevinj54
07-25-2012 17:06:05
 Re: Primer dry-time in reply to challenger, 07-25-2012 09:40:41
Read the can..........I think you have to re-coat within 3 hours or wait over 24 hours with the case paint.
gene nehring
07-26-2012 18:44:06
 Re: Primer dry-time in reply to kevinj54, 07-25-2012 17:06:05
3hr window
Stephen Newell
07-25-2012 15:23:11
I can't find out what the primer is. My instincts leads me to think it is an alkyd primer so I would not topcoat it in 12 hours. An alkyd primer needs 24 hours even in this heat.
Kurt_JDB
08-05-2012 19:08:18
 Re: Primer dry-time in reply to Stephen Newell, 07-25-2012 15:23:11
Is there an outside window for painting after the primer goes on, can you top coat it a week later?
Kurt
Stephen Newell
08-06-2012 04:08:47
 Re: Primer dry-time in reply to Kurt_JDB, 08-05-2012 19:08:18
I never could find out what type of primer this thread was about. When you use any new paint you should get a specification sheet from the paint supplier. It has the instructions that should be on the can. They don't put much instructions on paint anymore to make room for hazard warnings in three languages. I don't care for alkyd primers but with that type of primer you can paint over it in 24 hours or next year. There is no recoat window. I prefer to use epoxy primers. The recoat window varies from product to product but I think most you should topcoat within 72 hours. After 72 hours it hardens up so much you have to go over it and roughen it up with sandpaper to get good adhesion. Its a lot of work and Epoxy primers don't sand very well so it is usually easier just to put another coat of epoxy primer on if you exceed the recoat window.
sflem849
08-06-2012 04:51:43
 Re: Primer dry-time in reply to Stephen Newell, 08-06-2012 04:08:47
Kurt_JDB
08-06-2012 04:49:59
Thanks. Epoxy primer is what I plan to use. I would like to get a coat on there as I clean the parts up to prevent oxidation, with the plan to top coat later. If I can just shoot another coat of epoxy on there before the topcoat without having to sand/prep again, I'll be a happy guy.
Kurt
sflem849
08-06-2012 04:53:08
 Re: Primer dry-time in reply to Kurt_JDB, 08-06-2012 04:49:59
Some epoxy primers will let you recoat with epoxy without scuffing. I was going to follow the same plan your intend on following.
Copyright © 1997-2015 Yesterday's Tractor Co.
