Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Paint and heat
Jason S.
07-22-2012 08:29:32
Yes sunlight will help it cure...it's not really the heat but the ultraviolet rays that does it. Body shops use ultraviolet lights all the time to cure paint and primers. As far as the heat...if you walk in a paint booth right as the heat cycle goes off the paint will still be soft...but when the cool air hits it the paint hardens up. So if you let them bake in the sun for a while and then place them in front of the fan it should help.
glennster
07-23-2012 05:45:08
 Re: Paint and heat in reply to Jason S., 07-22-2012 08:29:32
jason, infra-red, not u/v. we use a spectra-therm 4000 short wave i/r for spot primer, but not for base/clear. we bake at about 140 degrees for 45 minutes or so in the booth. for paint and clear application, the booth temp on the spray cycle is set at 85 degrees. primers and sealer applications do not get forced dried, just thru the spray cycle. here is a link to a spectra therm 8000, the 4000 is a single head unit
