Oliver paint question
Benelli
I am getting ready to paint the engine and tub frame on a 1969 Oliver 2150 I have the agco green paint in meadow green. What do I thin this with and what would be a compatible hardener for this paint. Thanks for the help.
I would either get PPG's, Dupont or Martin Senour's paint. Depending on which paint you select they will supply you with the correct thinner and hardener. I would at least use Acrylic enamel. Hal
If you are going to use the agco paint just get synthetic enamel reducer and hardener. You can get it from most any paint store and my local oreillys carries it too
