8n wheel repair
This may not belong in this section but I have a 19in wheel that has come off an 8n and the part that the tire mounts on has rusted through. I was planning on a buying just the outer rim and filling in the center with the old wheel. Would a cutoff tool be OK to remove the center from the old wheel or do I need a acetylene torch?
I'd replace the wheel. If you opt for the repair, a cut-off tool would be cleaner. Don't weld on the wheel with the tire on.
http://www.ebay.com/itm/ORIGINAL-2N-9N-FORD-TRACTOR-FIRESTONE-1-RIB-19-WHEELS-TIRES-FORD-8N-/251096679207?pt=LH_DefaultDomain_0&hash=item3a76874327
another 19" wheel -
http://www.ebay.com/itm/FORD-8N-FRONT-WHEEL-/150851548775?pt=LH_DefaultDomain_0&hash=item231f73f667
common to weld a rim blank onto an old center.
remove the old rim as you can. grinder.. sawsall,, cutoff wheel.. plasma cutter.. torch.
I done em all.. torch was the easiest.. then hit it with a grinder a bit to clean up
lay flat and use blocks to prop the center to get it level in new rim.. use other rim as a measurement guide. tack in.. then remeasure.. and check for true all around.. then weld her in.. grind.. paint up and remount and go.
