Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: For CNKS: Picklex 20 coverage
CNKS
07-05-2012 14:30:58
JD M is small, you should have a lot left over. Spray a little on and spread it with a brush. I agree with Rod, do not use it as a rust converter, remove all the rust you can, and use it as a protectant, it will convert small amounts of rust. It is the best product you can buy used in that manner. Don't expect good results if your parts are covered in rust.
JRSutton
07-18-2012 15:09:11
 Re: For CNKS: Picklex 20 coverage in reply to CNKS, 07-05-2012 14:30:58
I'd agree - I think if you have heavier rust, it has to stay "wet" for at least 15 minutes for a phosphoric acid to make any difference.
So if you've got a lot of heavy rust, you'll be in the poor house in no time using picklex.
Not the right product for the job.
Sandblasting/wire brushing is the right product for that job.
Minor rust - be sure to let it stay wet for longer than you would clean metal.
On clean metal, just spray it on - wipe it thin with a cloth or brush and let it dry.
CNKS
07-05-2012 17:10:33
In addition, I notice that the instructions have changed. When I have used it, I squirted it on and spread it with a brush, then let it dry. The "new" instructions say to apply, brush it to spread it out, wait 1 minute and wipe it off with paper towels. It says if it dries on the surface, it will reduce bonding - don't know if that means the Picklex or the paint - and it will be hard to remove the residue. It used to say paint over the residue, which I never do. Also I have always been able to get most of the residue off by scuffing. Probably best if the instructions are followed. Wax and grease remover are not mentioned, if I remember right. To me that is mandatory, in addition to the instructions. Use epoxy over it, not etch primer as etch may add too much acid.
