TractorLinks.com
Re: how many coats of clearcoat?
CNKS
06-25-2012 15:09:05
About all I use single stage for is on some parts I remove from the tractor (cast). I have a matching single stage that I use for that. You are right, I am never going back to single stage on the sheet metal or the chassis, except for a few small parts. Clear is much easier to buff.
sflem849
06-25-2012 15:58:47
 Re: how many coats of clearcoat? in reply to CNKS, 06-25-2012 15:09:05
So you are doing the majority of your small parts base clear as well? Nuts and bolts?
CNKS
06-25-2012 17:09:54
 Re: how many coats of clearcoat? in reply to sflem849, 06-25-2012 15:58:47
I don't have a real good reason to clear small parts, so most of them I don't. You have to look real close to see the color difference. Some of the bigger small parts such as the oil canister, air cleaner, etc will be cleared, along with the fan shroud, front axle or bolster, etc. The bolts are painted with single stage urethane intially and touched up after installation, with of all things IH 2150, close enough for me, and I don't have to mix the hardener. So, I am using 3 kinds of paint on one tractor, and I challenge anyone to tell the difference. That is not to say I will paint a whole tractor with 2150, I won't. In small areas used as a touch up for chips, etc it blends in. I bought a quart of 2150 several years ago only to compare the color to PPG 71310-- I can't tell the difference. I still have 90% of it.
