TractorLinks.com
Re: epoxy primer wait time
Red Ford
06-09-2012 11:06:56
It requires extra care to sand PPG epoxy primer, but it IS sandable. If you wait past the recoat window it MUST be sanded. The heavier it is applied(yes, it can be used for high build), the longer you need to wait before sanding. And, the longer you wait, the easier it is to sand.
CNKS
06-09-2012 13:00:32
 Re: epoxy primer wait time in reply to Red Ford, 06-09-2012 11:06:56
It can be smoothed up if there is a drip or run if I am very careful. I have done that. By not sandable I mean not like surfacers or primer surfacers or other high build primers or even some of the cheaper red oxide or lacquer primers. PPG recommends 1 or 2 coats for the Omni version. I sand it only if I have made a mistake. Not much sense in using it as a high build when there are much better products available. IMO epoxy should be used as the base coat on everything. If outside the window it has to be scuffed or sanded, makes no difference if it goes to bare metal as it has to be reapplied. I haven't used Nason, perhaps it is formulated differently that allows it to be applied thicker. I see no advantage in that either. PPG MP 170 is really thin, probably the reason PPG recommends two coats, used to be one. I have always used two because I am not skilled enough to get perfect coverage with one coat.
Re Ford
06-14-2012 11:31:37
 Re: epoxy primer wait time in reply to CNKS, 06-09-2012 13:00:32
It depends on what you are doing. All the high build products I have tried are either too soft, too brittle, or don't have enough mechanical strength. Heavy epoxy application, lots of cure time, and skilled sanding, are the best I have found for my shop's jobs.
CNKS
06-15-2012 05:36:05
 Re: epoxy primer wait time in reply to Re Ford, 06-14-2012 11:31:37
With PPG Omni MP 182 surfacer I have had zero problems. It would take many applications of Omni MP 170 to do what you describe. To each his own.
