TractorLinks.com
Re: Rust oleum paint 7435402 john deere green. Old or new...
70 jd puller
05-26-2012 13:12:49
So i will not have any trouble if i use Naptha? I should try to shoot with out thinning first. How do i know if i should use thinner or naptha? How much psi should i use while spraying with a top canister spray gun? Do you work for rust oleum or just used it in the past?
Worker at rust oleum said to spray a coat in 15-20 min intervals 3-4 coats in a hour. or top coat at 48 hrs. works better if you dont wait 48 hrs do it in less than an hour. Thanks for your help. jm
Stephen Newell
05-26-2012 15:48:57
 Re: Rust oleum paint 7435402 john deere green. Old or new... in reply to 70 jd puller, 05-26-2012 13:12:49
If you put the paint in the gun and little or no paint comes out you will know it needs to be thinned. For a gravity feed gun you would probably use it at about 60-70 pounds. I don't have any connection with rustoleum. I'm a professional furniture refinisher. I do use rustoleum paint from time to time.
I can't find anything to support the idea of spraying the paint in 15-20 minute intervals. I looked online for a data sheet and couldn't find one. The only thing I could find is a handling sheet which said what I thought all along that it was just an alkyd enamel. You might look on the can for drying times but if it were me I would not put more than one coat on in a 24 hour period. I think if you would put 3 or 4 coats on in an hour most of it would run off onto the ground. I don't know if you're old enough to remember but the paint is very similar to enamel house paint.
