TractorLinks.com
Primer
patsdeere
05-25-2012 15:26:14
Ok, so if you had to choose between a white semi epoxy primer (which is sandable) or JD buff primer which would you pick? I will be using JD paint on top.
Thanks.
mike.l
05-26-2012 04:52:30
 Re: Primer in reply to patsdeere, 05-25-2012 15:26:14
stay with the john deere primer unless you got supplyed air john deere primer might help you to live a little longer
patsdeere
05-28-2012 21:59:58
 Re: Primer in reply to mike.l, 05-26-2012 04:52:30
Thanks for the warning. I do have a supplied air system and don't know how I did it without it. What a lifesaver.
sflem849
05-29-2012 05:30:09
 Re: Primer in reply to patsdeere, 05-28-2012 21:59:58
What are you running? How do you like it?
CNKS
05-26-2012 09:47:59
True epoxy primers do not usually contain isocyanates, but best to check the MSDS to be sure. The PPG versions do not.
CNKS
05-25-2012 16:52:45
Use non-sandable (true) epoxy primer followed by a surfacer. What is the name of the sandable (semi)epoxy?
