TractorLinks.com
Re: Rust oleum paint 7435402 john deere green. Old or new...
70 jd puller
05-23-2012 18:48:14
The paint is Rust oleum BRAND. It says if thinning use mineral spirits. Is Naptha the same just dries faster? The color looks good i compared it to martin senoir on my G, looks good. It also says for best results use rust oleum primer, is there any other primer i can use if i cant find that brand? What brand hardener should i use? Some say only to put hardener on last coat when all done. True?
Stephen Newell
05-26-2012 05:35:01
 Re: Rust oleum paint 7435402 john deere green. Old or new... in reply to 70 jd puller, 05-23-2012 18:48:14
When paint is sprayed, it needs to be thin enough to go through the gun. An alkyd dries so slow it invites runs so the naphtha is used as the thinner because the paint will dry a little faster and is not as prone to run. Usually what I try to do is spray the paint with thinning it at all. Today many paints are watered down and you can spray it right out of the can. It's always better to not to thin it more than necessary to spray it.
Well they say it's better to use the Rustoleum primer because they’re selling primer. Any new metal is better primed with epoxy primer. The epoxy primer will provide a barrier to rust that no other primer will provide. Other primers will allow metal to rust underneath the paint. Often you can see painted metal with rust bleeding right through the paint. This won't happen with epoxy. One thing I forgot to mention is epoxy primers have a recoat window, which means you have to topcoat within usually 72 hours or it has to be scuffed or re-primed. Also epoxy primer is not a sandable primer. If you need to sand and level the finish you will need a filler primer over the top to work it. I use Evercoat Featherfil for that purpose. It's a fiberglass filler that smells like bondo.
I can't really help you on brand of hardener. I only have access to the Valspar hardener for an alkyd. It is available at Tractor Supply Stores. I've asked for it at Sherwin Williams and they said they didn't have any. Perhaps the clerk didn't know his business, I just haven't asked again.
70 jd puller
05-26-2012 07:14:03
 Re: Rust oleum paint 7435402 john deere green. Old or new... in reply to Stephen Newell, 05-26-2012 05:35:01
Thanks. So mineral spirits and naptha are chemically the same except naptha dries faster? Naptha won't chemically ruin the paint?
70 jd puller
05-26-2012 13:12:49
 Re: Rust oleum paint 7435402 john deere green. Old or new... in reply to 70 jd puller, 05-26-2012 07:14:03
So i will not have any trouble if i use Naptha? I should try to shoot with out thinning first. How do i know if i should use thinner or naptha? How much psi should i use while spraying with a top canister spray gun? Do you work for rust oleum or just used it in the past?
Worker at rust oleum said to spray a coat in 15-20 min intervals 3-4 coats in a hour. or top coat at 48 hrs. works better if you dont wait 48 hrs do it in less than an hour. Thanks for your help. jm
Stephen Newell
05-26-2012 15:48:57
 Re: Rust oleum paint 7435402 john deere green. Old or new... in reply to 70 jd puller, 05-26-2012 13:12:49
If you put the paint in the gun and little or no paint comes out you will know it needs to be thinned. For a gravity feed gun you would probably use it at about 60-70 pounds. I don't have any connection with rustoleum. I'm a professional furniture refinisher. I do use rustoleum paint from time to time.
I can't find anything to support the idea of spraying the paint in 15-20 minute intervals. I looked online for a data sheet and couldn't find one. The only thing I could find is a handling sheet which said what I thought all along that it was just an alkyd enamel. You might look on the can for drying times but if it were me I would not put more than one coat on in a 24 hour period. I think if you would put 3 or 4 coats on in an hour most of it would run off onto the ground. I don't know if you're old enough to remember but the paint is very similar to enamel house paint.
Stephen Newell
05-26-2012 12:38:06
Mineral spirits and naphtha are two different chemicals however both are compatable with the Rustoleum paint. You can use either one. You just need to be a little more careful with runs using mineral spirits than naphtha.
