TractorLinks.com
Re: Farmall Paint
CNKS
05-17-2012 19:02:33
Dupont, PPG, Martin Senour, etc. Stay away from farm store or hardware store paint. You need more than just a gallon of paint. To do it right you need epoxy primer, followed by a sandable surfacer on the sheet metal to get a smooth finish. You also need to go to bare metal and remove all the rust, then use body filler after you have leveled the dents as best you can. The best paint is acrylic or poly urethane, but it requires hardener which contains isocyanates, which can make you sick. For hardener you need a supplied air system, a charcoal mask will not do. To avoid hardener you can use acrylic enamel. You can also use CaseIH 2150 which is an acrylic modified alkyd enamel. I have not used it but it has good reports. It contains some UV protection to resist fading. PPG/DuPont codes for 2150 are 71310/96766.
