Yesterday's Tractor Co.
Shop Now View Cart
Re: what kinda primer to use on bare metal
bill n texas
05-05-2012 17:51:29
I will be just sand blasting the frame,rims and small parts right might be several weeks before I will paint the whole thing...I need a primer that can sit for awhile.if you know what I mean..thanx..bill
Stephen Newell
05-05-2012 18:46:26
 Re: what kinda primer to use on bare metal in reply to bill n texas, 05-05-2012 17:51:29
Yea I know how big a project it is to paint a tractor. The epoxy primer is good stuff, you just need to topcoat it with a sealer or a coat of your finish coat within the recoat window. If you exceed the recoat window you can scuff the primer or just put another coat of primer on before proceeding. Look at it this way, if you use the epoxy primer it will be as close to a factory paint job as you can get and will last much longer than other primers and will keep you from having to do this job again for a very long time.
bill n texas
05-05-2012 20:22:23
 Re: what kinda primer to use on bare metal in reply to Stephen Newell, 05-05-2012 18:46:26
Thanx to all...I will prime with epoxy..
Rod (NH)
05-05-2012 18:10:25
Ditto on the epoxy.
05-05-2012 18:04:49
You either use epoxy primer and paint within the window, or if outside the window scuff it and give it another coat. Epoxy is such a good primer that I won't recommend anything different. If you are afraid of rust, use Picklex 20. It is a rust preventative that comes in a squirt bottle--you can spray on and level out with a brush. It will keep rust off for months. Do not wash it off. When you get ready to paint, scuff the white residue off with a scotchbrite pad, follow with wax and grease remover, apply epoxy and topcoat within the window. You will want to put a sandable surfacer over the epoxy on the sheet metal in order to get a smooth surface. If you are using body filler, although it can be applied over the epoxy, I prefer bare metal, as you have to apply the epoxy again anyway after you sand the filler.
