| Antique Tractor Paint and Bodywork |
Topic: Re: what kinda primer to use on bare metal
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Stephen Newell
05-05-2012 16:50:16
66.53.80.199
Etching primer is mostly used on cars when no body work is needed and you can just prime it and topcoat quickly. Epoxy primer will provide better rust prevention and is better for tractors because they are chemical resistant. Each epoxy primer is different so you need to get a spec sheet with whatever primer you use. I use Nason Ful-Poxy 491-16. It has a 72 hour window in which it has to be topcoated but epoxy primers don't sand like oil based primers. They dry so hard if sanding and leveling is needed a filler primer should be put over the top so I use Evercoat Featherfil over the top. After coating with the Featherfil there is no recoat window. I can sand it and work it anytime. If bodywork is needed I put the fiberglass filler over the epoxy primer before the Featherfil. Anyway you can prime the metal parts with the epoxy primer and let set indefinitely. If you go much beyond the recoat window you will need to put a fresh coat of epoxy primer before preceding. |
| bill n texas
05-05-2012 17:51:29
174.238.192.69
Re: what kinda primer to use on bare metal in reply to Stephen Newell, 05-05-2012 16:50:16
| I will be just sand blasting the frame,rims and small parts right now.it might be several weeks before I will paint the whole thing...I need a primer that can sit for awhile.if you know what I mean..thanx..bill |
| Stephen Newell
05-05-2012 18:46:26
66.53.80.23
Re: what kinda primer to use on bare metal in reply to bill n texas, 05-05-2012 17:51:29
| Yea I know how big a project it is to paint a tractor. The epoxy primer is good stuff, you just need to topcoat it with a sealer or a coat of your finish coat within the recoat window. If you exceed the recoat window you can scuff the primer or just put another coat of primer on before proceeding. Look at it this way, if you use the epoxy primer it will be as close to a factory paint job as you can get and will last much longer than other primers and will keep you from having to do this job again for a very long time. |
| bill n texas
05-05-2012 20:22:23
174.253.23.45
Re: what kinda primer to use on bare metal in reply to Stephen Newell, 05-05-2012 18:46:26
| Thanx to all...I will prime with epoxy.. |
| Rod (NH)
05-05-2012 18:10:25
69.131.62.24
| CNKS
05-05-2012 18:04:49
216.144.104.128
| You either use epoxy primer and paint within the window, or if outside the window scuff it and give it another coat. Epoxy is such a good primer that I won't recommend anything different. If you are afraid of rust, use Picklex 20. It is a rust preventative that comes in a squirt bottle--you can spray on and level out with a brush. It will keep rust off for months. Do not wash it off. When you get ready to paint, scuff the white residue off with a scotchbrite pad, follow with wax and grease remover, apply epoxy and topcoat within the window. You will want to put a sandable surfacer over the epoxy on the sheet metal in order to get a smooth surface. If you are using body filler, although it can be applied over the epoxy, I prefer bare metal, as you have to apply the epoxy again anyway after you sand the filler. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
