Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Paint codes
Sam Wigeon
03-30-2012 17:28:21
Time to paint the hood of my late 1975 White 2-105. Is there anywhere to find paint codes for that gray/silver color for this tractor? I thought this would be easier than a visual matchup.
2busy
04-01-2012 14:54:42
 Re: Paint codes in reply to 135 Fan, 03-30-2012 17:28:21
Thanks guys. Gary, have you actually compared the 7566 to the original charcoal gray met. on the tractor? Is it an exact match? Have you repainted a tractor with it? If so could you post a pic? Thanks again for the info!
Gary in da UP
04-02-2012 11:58:36
 Re: Paint codes in reply to 2busy, 04-01-2012 14:54:42
The codes were taken from this color deck, I have not verified match with a white tractor.
sw tractor paint chip chart
Gary in da UP
04-01-2012 09:20:48
 Re: Paint codes in reply to Sam Wigeon, 03-30-2012 17:28:21
The argent silver metallic is Sherwin-Williams code 7567 , the charcoal gray mtallic is 7566. The numbers should be the same in MS, add the appropriate prefix for the system you are using.
2busy
03-30-2012 18:39:26
I am in the process of painting a 1977 White 2-155. I am using the Martin Senour crossfire paint from napa. The silver number I used is 53B 4869, that was looked up at napa. As for the Charcoal gray, I have not been able to find the correct number. I had napa mix some of the number they had and it was not the right gray. If anyone knows a paint code for the charcoal gray metallic please let me know. Thanks.
El Toro
04-01-2012 19:39:36
 Re: Paint codes in reply to 2busy, 03-30-2012 18:39:26
Dupont has a dark gray for White tractors. There's no metallic. Try Sherwin Williams. Hal
Sam Wigeon
03-31-2012 14:43:19
Thanks, and if I find the charcoal gray code I'll hunt you down. swigeon
Copyright © 1997-2015 Yesterday's Tractor Co.
