OEM paint over epoxy primer
BETA
New User
Is there any problem shooting OEM New Holland (industrial yellow) acrylic enamel over epoxy primer? This will be on the chassis so I'm not concerned with being able to sand to a smooth finish before final coat. The yellow will not have any hardener, just the paint.
There shouldn't be a problem unless you've exceded the recoat window on the epoxy primer. If you've exceded the window I would refer to the instructions on the primer. It may be necessary to scuff and prime it again first.
I used their acrylic enamel blue on my garden tractor over epoxy primer in 2010. I used a surfacer over the primer before shooting the blue. Hal
