TractorLinks.com
Re: What Kind of sander
glennster
03-13-2012 03:44:50
for body work using filler, an air file and a d/a would be your best choice. however, if your on a budget, a good orbital type electric sander would get you by. for major filler work ie "bondo" pick up a long board manual sanding block. you will need to level the filler with 36 grit, then a second thin filler application, hit it with 80 grit on the long board to check for any high spots, then use a small hand block for final shaping. after that, use 120, 220, then 320 on the electric orbital for final finishing before priming and painting. a sure form cheese grater is also handy to shape the initial filler application. work the filler right after it sets up before it gets hard as concrete, its a lot quicker to sand.
