TractorLinks.com
Re: Acid wash
ShadetreeRet
03-07-2012 18:33:00
To be honest, I don't know that much about the stuff. But I would check the label to see just what else may be in the stuff from Home Depot, 'cause that is awful cheap compared to the others. But if there is enough phosphoric acid in it to get the job done, then I would go for it. Kinda like buying a car or truck, when you pass a certain price you are just paying for the name. Just my thoughts.
redman88
03-18-2012 09:24:42
 Re: Acid wash in reply to ShadetreeRet, 03-07-2012 18:33:00
I bought the same stuff from home depot( klean strip) ( phosphoric prep and etch). I use in on my tractor because I had a lot of rust on it before I sand blasted it. I blasted then took the klean strip and applied on tractor with a small brush like it said in the directions. The thing I noticed after letting it dry was spots that were like a white crusty film left on the top. I am a little concerened about this because if you try to wipe it off with a dry shop towel it kind of gets imbedded into the cast like writing with a piece of chaulk. This is my first time using this product and the first tractor restore. I am planning on just wiping it done with a wax and geese cleaner and then maybe mineral spirits right before paint day.
redman88
03-18-2012 09:31:16
 Re: Acid wash in reply to redman88, 03-18-2012 09:24:42
I will show a picture of the tractor after treating it with klean strip phosphoric and you can see all the white film on it and the blues and greens in the metal. I think the discoloration I'd due to the chemical reaction between the metal, rust and klean strip.
redman88
03-18-2012 09:24:00
CNKS
03-18-2012 14:56:10
 Re: Acid wash in reply to redman88, 03-18-2012 09:24:00
Use wax and grease remover as the final step, not mineral spirits. Ok to use mineral spirits before wax and grease remover. As to your acid, although I have done it once, I do not recommend H3PO4 on any kind on cast, it may get in the pores and lift the paint later. The one time I did it with Picklex 20, it did not lift. If you insist on it, repeatedly use about any cleaner to try to get it out of the pores followed by wax and grease remover. Looking at your picture, you used far too much acid. It does not take much. The "dirtier" the cast, the more white residue you will have. On clean sheet metal, for example, there is very little. Using a product such as Picklex 20, which is a mild version of H3PO4 the white residue can be mostly removed with a scotchbrite pad, followed by wax and grease remover. After I had painted my 1st tractor, it dawned on me that I do not need any form of H3PO4, because I live in a dry climate, and I simply do not get rust on bare metal inside my shop.
redman88
03-18-2012 09:22:20
