Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Surface Cleaning For Epoxy Primer
glennster
03-06-2012 09:28:26
for final cleaning i load a sure shot with wax and grease remover. i got it from napa, its a one quart metal can with a spray tip, you can load it with solvents or penetrating oil and pressurize it with an air hose. they are about 30 dollars or so. shoups sells them also. if you dont want to buy one, you can use an old spray gun, turn the air pattern all the way in so it shoots a small circle pattern and hose the cast down with that. start the final cleaning with something like mineral spirits, or cheap lacquer thinner (careful thinner atomized is highly flammable) then finish with pre-cleano type wax and grease remover.
