Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Surface Cleaning For Epoxy Primer
WD9ER
03-05-2012 15:06:54
Okay, hopefully glennster responds. I do not have a floor drain in my shop, but I usually wet the floor down to keep dust down when I paint. I have been trying to avoid using any water on the tractor to prevent rust. I more so thinking along the lines of an alcohol based cleaner that will evaporate.
glennster
03-06-2012 09:28:26
 Re: Surface Cleaning For Epoxy Primer in reply to WD9ER, 03-05-2012 15:06:54
for final cleaning i load a sure shot with wax and grease remover. i got it from napa, its a one quart metal can with a spray tip, you can load it with solvents or penetrating oil and pressurize it with an air hose. they are about 30 dollars or so. shoups sells them also. if you dont want to buy one, you can use an old spray gun, turn the air pattern all the way in so it shoots a small circle pattern and hose the cast down with that. start the final cleaning with something like mineral spirits, or cheap lacquer thinner (careful thinner atomized is highly flammable) then finish with pre-cleano type wax and grease remover.
CNKS
03-05-2012 17:12:07
As to the water, I do a small section at a time and dry it with a towel before I get flash rust.
