TractorLinks.com
Re: soda blasting machine
david hale
02-28-2012 08:54:31
Thanks for your comments. . . I have tried the wire brush on this rust. It takes off the surface rust but it eventually only polishes the deep rust. I considered comercial blasting and found a couple of places around phoenix. The price they quoted me was very high.. Like $300 for a wheel. SoÖ. Why not purchase. The Allis g has little tin and I can get to it to sand but the frame is made of more curves that the Rockettes. Sanding is just out. I have decided on a blasting machine, and was hoping to be able to use soda because I donít have space outside for the sand to fly. What I need further advise on is the blaster itself. I'd like to purchase a good quality unit but not top end, because of the $ involved. But I have no understanding what blasters are quality or not. I know there are some at Harbor freight, but not sure they are good enough to remove the rust. How do I spot a good quality unit and what should I expect to pay. I will be upgrading my compressor to match it. But I just donít have the experience to know what to look for on a blaster.
CNKS
02-28-2012 15:02:35
 Re: soda blasting machine in reply to david hale, 02-28-2012 08:54:31
I was in the same situation as you. I bought a 30 gallon Chinese blaster, about 1/2 the price of a US one with the same capacity. Works ok but sometimes the air pulsates. Will hold about 80-90 lbs of sand that lasts me maybe 10 minutes, then I have to screen the sand I put in because I have to use a small tip to let the compressor keep up. My compressor puts out 24 cfm at 100 psi, 80 gallon two stage. If your Allis G is what I think it is, rear engine--it will work ok on from the engine forward. I wouldn't want to sand or wire wheel that either. Buy quality fine sand, not the stuff from Home Depot, next to impossible to screen. I get mine from a non big box lumber yard. Since my compressor won't handle a bigger blaster, I limp along with my cheap one. Be sure you get a pressure blaster, not one that sucks the sand from a bucket.
david hale
03-04-2012 21:23:38
 Re: soda blasting machine in reply to CNKS, 02-28-2012 15:02:35
thanks
