showcrop
I am spraying high build primer over epoxy. The primer is not coming out of the gun consistently. The sprayer is a cheap old suction feed unit. Sometimes the paint comes out when I squeeze the trigger sometimes not. I tried adjusting the amount that it opens with trigger pull, didn't seem to help. The primer is also drying sometimes before hitting surface. I adjusted pressure down to just above where it would pull the best. I disassembled and found no blockage. A friend who paints a lot more than I do has suggested a top feed unit. I have to pick up more paint so I plan to get one to try.
