TractorLinks.com
Re: Problems spraying high build primer
showcrop
02-13-2012 09:37:11
I am using Nason 421-17 urethane primer with 483-87 activator. I don't know the size of the tip, it is the one that came with it. I checked the vent, it was OK. I found one of the four very small holes in the nozzle was plugged. The label instructions don't call for any thinning.
Rod (NH)
02-13-2012 10:52:52
 Re: Problems spraying high build primer in reply to showcrop, 02-13-2012 09:37:11
Here's the full tech sheet on the 421-17. You probably have the general purpose 1.8mm tip that was pretty much strandard on the older gravity feed guns so that should be OK. Make sure your gun pressure (35-45 psig) is set AT THE GUN. I see the pot life is only an hour, similar to the PPG surfacer that I use. Don't let it sit around mixed before using. Spray it as soon as you mix it. As the pot life approaches and is exceeded, the stuff thickens up rather fast. That in itself could lead to spray problems with any gun.
