TractorLinks.com
Re: Problems spraying high build primer
CNKS
02-13-2012 06:47:00
I have sprayed with a HVLP gun for PPG Omni 182. I use a 1.8 tip. It sprays fine, leaves a rough surface, but it has to be sanded anyway. I know nothing about suction feed guns, but if the gun is clean you need to thin it. MP 182 works fine without thinning, but gets slightly thinned with a ratio of 5:1 primer to hardener. With HVLP use the maximum pressure at the gun, which gives 10 psi at the tip. I have never messed with the pressure and the wide open pattern for topcoat or primer.
