Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Paint Chipping
DScott
02-06-2012 11:45:17
One of the first tractors (a John Deere B) I ever painted did this and I think it was caused one of or both of these reasons:
1-Waiting too long to paint the tractor after it was primed. To achieve chemical bonding most primer has a "window" for when the top coat should be applied for optimal results due. I didn't realize this at the time and I also didn't sand the primer down good before painting, which is advised when painting outside the "window". Which resulted in the paint not having a good chemical or mechanical bond.
2-Used too much hardener. I didn't pay much attention to measuring out my measuring technique and I realized I had use way too much hardener when I ran out way before I was through. The paint was always real brittle and flaked off to the primer if handled at all.
After the fact there wasn't much I could do except be careful with it and touch it up as it happened. I think now that probably waiting too long after applying the primer and then not sanding it was the most likely cause of the problem in my case. That was the first time I had ever painted anything and without any hands on guidance I was fortunate that it turned out any good at all.
