I know the topic of "black oxide" after using a rust converter / electrolysis has been covered before ...and there even are conflicting opinions on it....but...
I have been stripping paint from some cast iron parts using a wire wheel / angle grinder and after the paint comes off there there seems to be a black layer that I need to get thru before the iron becomes shiny. On some pieces it takes quite an effort to get thru the black layer.
I've also played around with cleaning the cast to shiny and letting it sit there for some time to see what happens to it. While I don't see any red rust type of coating, the cast will definetly get dull and turn dark (black ?). I aasume that is a form of oxidation. In some articles I read that it is a stable form of oxidation as opposed to the red oxidation which is not.
Question is...can you prime over this black layer or does it all have to be shiny clean before primering ??
Any opinions welcome...Thanks...Alan
