(quoted from post at 08:25:50 09/02/11) Thanks eltoro i have a pressurerised tank i going to look around to see if i can run soda threw it if not i will sand blast carefully.Do you know what kinda primer he uses.
be sure to use an acid wash before priming unless you plan to sell it in less than three years. Any little pits in sheet metal or depressions in the cast iron will hold onto little flecks of rust which will slowly grow under the paint. The phosphoric acid converts rust to inert iron phosphate.
You need to follow the instructions with the acid wash. The little bubbles under the four year old paint on hood panels that had pits and didn't get acid washed give me heartburn.(quoted from post at 06:49:01 09/07/11)be sure to use an acid wash before priming unless you plan to sell it in less than three years. Any little pits in sheet metal or depressions in the cast iron will hold onto little flecks of rust which will slowly grow under the paint. The phosphoric acid converts rust to inert iron phosphate.
Decide what primer you'll be using first...a lot of Epoxy primers do not behave well on top of acid washes. On something like cast, it may be virtually impossible to completely neutralize the acid...causing you tons of heartburn down the road.
