I have never had this problem before and am not sure why it even happened. I shot the primer on early in the morning and let the parts dry out in the hot sun all day. After they had been drying for well over 8 hrs and felt dry and solid, I wet sanding down to s very smooth finish, getting them ready for color, after I got done sanding there were a couple little divots that were barely visible but I wanted a good smooth surface so I used to Bondo glazing and spot putty on the little spots to level them. When I put the putty back in the cabinets and by the time I turn around the paint had lifted where I put the putty. I used an oil based primer thinned with naptha, it went on great and was plenty dry. Has anyone ever had anything like this happen before. I typically use a lacquer or urethane primer but I had this primer in the garage and though I would use it for this tractor, it has been doing fine til this. I shot the whole tractor with this primer and already topcoated the chassis with no problem, but now I am on the sheetmetal and really wanting it smooth, so if it is going to react this way to the spot putty, I will have to strip it and go with another primer. Has anyone else had this problem?
