TJ in KY
I just wanted to thank B-maniac, CNKS, SWMO and Gordo SD for the advise on my painting problems.
I made some changes, added a loop of hose on floor for now,and now the separator seems to be working a lot better. I had one of those light bulb moments when I started using die grinder with wire wheel, previously would get a little moisture out of the tool, but not now, nothing, DUH, I said to myself, this has to be the problem with the paint gun. Oh well, live and learn. I guess the old adage of “If you aren’t learning anything, you must not be doing anything “ is true. I still have a lot to learn, still have a lot to do on this tractor. Thanks again
Tom
Tom
