Farmall Super C
For sheet metal
1 Sand the paint off to bare tin.
2 Use body filler to fill in small dents and craters
3 Use 1 coat case ih buff primer with hardener.
4 Then use Case IH primer with hardener (2-3 coats and sand between coats)
5 Lastly apply Case ih 2150 paint with hardener (2-3 coats) (Do I have to sand between coats for this one?)
Then for the Cast parts
1 Wire wheel the cast parts to bare iron
2 Use 1 coat case ih buff primer with hardener.
3 Then use Case IH primer with hardener (2-3 coats)
4 Lastly apply Case ih 2150 paint with hardener (2-3 coats)
Is there any thing missing that I should do or anything I should change?
For sheet metal
