TractorLinks.com
oliver 70 PPG Paint codes
DH in PA
11-19-2007 12:23:26
Iam looking for PPG bc/cc paint codes for 1947 oliver 70 DH in Pa
MIKE FRENCH
11-21-2007 13:46:57
 Re: oliver 70 PPG Paint codes in reply to DH in PA, 11-19-2007 12:23:26
sorry just have Martin Senour #s, you can use them and cross them over. green 99L-8748 red 99L-3752 yellow 99L-11611 hope this helps, Mike
DH in PA
11-20-2007 12:47:31
Thanks for the reply! Next question,which oliver green belongs on 1947 70? And is your yellow the one used on 70 grill? If I keep digging and scratching I will get it right I hope! Thanks DH
GlenIdaho
11-20-2007 22:23:34
 Re: oliver 70 PPG Paint codes in reply to DH in PA, 11-20-2007 12:47:31
Hi DH; Sorry can't help you further. I'm not that familiar with Olivers. Have you tried the Oliver forum? Might be someone there who can help.
GlenIdaho
11-19-2007 19:51:10
DH; Here are the codes courtesy of Rod(NH). Rod is a knowledgeable and respected contributor to this site. He as well as others have been a tremendous help to me and others. Below is a Caution he gives as well as the PPG Oliver Codes.
PPG Automotive Finishes
Tractor and Implement Colors
"Caution: This list was assembled using three different PPG sources plus input from others. There was no information concerning model or year, except as noted. Use this list at your own risk. There are no guarantees. I have only confirmed the AC early persian orange, sometimes referred to as "persian #1", as 60080. Most of the codes should be available in most, if not all, current PPG automotive paint chemistries, including the economy OMNI line. See your local PPG jobber for details. I strongly suggest first purchasing the smallest possible quantity in an attempt to verify the proper shade. Custom mixed colors are not returnable. Unfortunately, whenever a color proper name has multiple codes listed against it, I have no idea which one is appropriate for your application. If you are particular about shade, you may have to sample them all. If you wish to get information on the different chemistries available from PPG, including technical data sheets (detailed usage info) and material safety data sheets (MSDS=safety & health info), go to the PPG website."
Oliver Clover White (1959)------------------8229
Oliver Clover White (1959)------------------8805
Oliver Cletrac Orange-----------------------60583
Oliver Equipment Dark Charcoal---- ---------33768
Oliver Equipment Dark Charcoal--------------34347
Oliver Equipment Dark Charcoal #90833-------33194
Oliver Equipment Green (1959)---------------42638
Oliver Equipment Silver Poly (Met.) #90832--8960
Oliver Equipment Green (1959)---------------41223
Oliver Green--------------------------------45132
Oliver Green--------------------------------40249
Oliver Green--------------------------------40812
Oliver Industrial Yellow (1959)-------------81154
Oliver Industrial Yellow (1959)-------------82335
Oliver Orange-------------------------------60433
Oliver Yellow-------------------------------81892
