Tractor has always smoked pretty bad and I could smell burnt fuel out of the tail pipe but its worse now after resealing the injector pump. Tractor is running good no leaks out of the pump like before. Not using any oil.
Ive blocked off the thermostarter. I also blew air back in the fuel tank from the hose coming from the top of the secondary fuel filter and reservoir and it was clogged up so now Im going to work it for awhile to try to burn the sludge out of the muffler.
Are those the return lines coming from the top of the secondary filer and small reservoir back to the fuel tank? I cant see in the fuel tank if any fuel is coming out of the return lines. Should I check the vent plug on the top of the secondary fuel filter?
