Hi. Can anyone give an idea of what the optimum Lift Pump pressure should be on these engines? If a range (e.g. 2-5 psi) how might the lower pressure show itself while in operation?
On this same tractor (2011 Branson 3120), would also like to know what the 'Output' pressure of the Injector Pump is supposed to be. (Injector Pump is 'VE' type manufactured under license by Zexel. There's also the name 'Doowan' or 'Doohan' on the pump tag.)
Thanks in advance. Tech data seems extremely hard to come by for this tractor . . .
