White 1270 Tractor
Nory
New User
Hi,
I have a White 1270 Tractor. I ran it out of diesel fuel. How do you bleed it?
Also, how much antifreeze does an empty radiator of the WHITE 1270 take?
I think they are the same as 1265 Oliver. I would loosen a couple injector lines at
the injectors and crank machine over until you get fuel at injector. Tighten lines and
that should bleed the tractor
I'll second what TF said. There are bleeders on the injector pump and a hand pump lever on the fuel pump. Open them and use the
hand pump, but I'd give it about a 1% chance that you'll start it without towing it.
