Differential needed made by HAXCO Part# HA251 or similar
I have a 1974 Alsport Tri Sport SL Trike that used a differential/axle from that company. If I can upload a pic I will.
I need it or something similar to put this trike back together. The reason for wanting that part is because it is made of steel from an Old manufacturer of Tractors, Holtan Axles & Transmission Co. Inc and it will hold up to hard shifts from a motorcycle motor that is more HP than the Trike ever came with.
It was actually one of two axle/differentials that this Trike was made with. The part # is HA251. HAXCO is stamped right on it.
I hope someone out there can help me with it or suggestions. If it was actually something for a particular tractor or lawn tracker, I unfortunately cannot get enough info to figure it out.
This is website to see photos in case they didn't upload for this post:
https://www.oldminibikes.com/forum/go-karts/24897-differential-setup-alsport.html
Thank you so much,
Herman
[email protected]
Thank you so much,
Herman
[email protected]
