Hey guys new to this forum and repairing mowers. I have come across a heckendorn mower, the problem is it won't start. I tried starting it the other day and it was turning over as a normal engine would. I then stopped turning it over to pull the choke out and when I went to try and start again the mower was dead. I mean I have nothing it won't even try to start now.
Things I have tried:
Battery check 12volts
checked wiring and fixed a couple crappy connections
ignition switch
The one thing I notice is the mower won't move meaning I can't push it cause it seems like it is locked up. The other two heckendorn mowers I am able to push when they are not running. So maybe the mower is in gear and it's not allowing it to start?????
Any help will be appreciate it.
ignition switch
