1948 mm
I have a rounder l600 skid steer with an onan engine and a no11 carbuerator with a vacuum fuel pump attached to the carb. I want to add an electric pump and eliminate the vacuum pump altogether. How do I do this?
Hi disconnect the pulse hose from the engine to the carb/fuel pump block the hose and the pump pulse inlet and install the electric pump inline and run the gas thur the old pump.
GB in MN
If you are having fuel flow problems, suspect the Carburetor Float..it may have swelled a bit..
I am in the process of dealing with that..
Have had an electric [ump on it for years and no improvement..
Bought a good used carb on-line (cheaper than buying a Float alone)..
Had that old one apart many times and tried to work down the places that were rubbing...didn't help much..
